NXOpen command that will Reset Block Styler dialog
lklo
Industrial
DK
hi -
In my current project, I'm trying to build in a button, that will do the same action, as when the "rounded arrow" in upper right corner, of a Block Styler dialog...
The action shall simply be to "Reset" the dialog - either by the rounded arrow or the Action button I have build into the dialog....
(using VB.Net & NX11.....)
Anybody of you guýs, that are aware about if a command already exists...?
remark: I did try to trigger the Sub: initialize_cb by calling this Sub when the custom Reset Button was hit,,,,but seems like it do not work...
br lklo...
 https://files.engineering.com/getfile.aspx?folder=bbfb2089-ac7f-4c12-ba0d-e308be5b42f4&file=reset_command_.png
I am also was need that
and tried very hard to find that.
but I failed.
and I think that there is nothing.
