NXOpen
Kodi10
PL
Hello everyone
I'm starting to use NXOpen capabilities (beginner) and I want to build dynamic library file using application Codeblocks IDE *.DLL. When I try to build a portion of code see bellow (this only beginning of all functions):
#include <iostream>
#include <conio.h>
#include <string>
#include <cstring>
#include <fstream>
#include <cstdlib>
#include <cstdio>
#include <cmath>
#include <windows.h>
#include <time.h>
#include <clocale>
#include <stdio.h>
#include <string.h>
#include <uf_ugopenint.h>
#include <uf5.h>
using namespace std;
extern "C" DllExport void ufusr( char *parm, int *returnCode, int rlen )
UF_initialize();
I receive this message with error:
obj\Debug\main.o||In function `ufusr':|
main.cpp|33|undefined reference to `UF_initialize'|
||error: ld returned 1 exit status|
||=== Build failed: 2 error(s), 0 warning(s) (0 minute(s), 0 second(s)) ===|
in addiction in compiler settings I indicate this two folder with libraries:
\UGOPEN\NXOpen\UGOPEN
Can anyone tell me what is wrong?
Thanks for all tips.
Some example code ships with NX, which might help you get started; they can be found at: C:\{your NX install folder}\UGOPEN\SampleNXOpenApplications.
More code examples can be found in the GTAC solution archive:
search for "nxopen" and filter for your language of choice to see all the examples for that language. These are supposed to be moved over to the new support site soon; some examples are there already, but I'm not sure where they hid the code samples there.
www.nxjournaling.com
