Glenn Gordon
I have an application where I would like to use an o-ring as an extension spring.
It is not a heavy duty application and it is not subject to any cyclical loading.
This o-ring in this mechanism is to hold tension between two pins whose center to center distance are infrequently adjusted.
Can you recommend what o-ring material would offer the best longevity in this application?
Glenn
Glenn
