O-ring as an extension spring?
Glenn Gordon
10
I have an application where I would like to use an o-ring as an extension spring.
It is not a heavy duty application and it is not subject to any cyclical loading.
This o-ring in this mechanism is to hold tension between two pins whose center to center distance are infrequently adjusted.
Can you recommend what o-ring material would offer the best longevity in this application?
Thanks,
Glenn
That would depend on the environmental conditions.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
The o-ring is in contact with two stainless pins and the ambient air (room temperature).
Glenn
If you look at the ASTM D 2000 and/or SAE J200 spec for rubber there are a few materials that have ultimate elongation as high as 600%. Given the minimal stated requirements, one of these would be "best". However, I suspect in this case the "best" would be whatever the local building supply has on hand.
Nitrile would probably work fine too, and be a bit cheaper than epdm. It would also relax less (maintain a more constant tension over time). But, epdm will stand up to a lot more stuff (ozone, uv) that might be coming through your "ambient air". We use a "bungee cord" to hold a lid on a product that sits in a potentially ozone filled, potentially moist environment, we fabricate the cord from some 1/8" epdm cord stock.
