O ring for cars
Help my o ring is either backed on or swelled up wont let me remove my part out, its stuck wont turn
? A little bit of context would help us?
Im sorry, just trying to get a crankshaft sensor out and the top broke, i am trying to do this myself, first time ever working on a car, i have no help, there is a o ring on this part, im guessing its baked on or swollen on, my searches resulted in drilling a hole, but my mind is telling me to try to chemically get rid of the o ring so it will pop out, there is no threads on this part
Don't believe there is anything that will dissolve an o-ring. 0-rings are fairly tough.
The best option is to drill a hole, tap it, and put a screw in it, so that you can pull the rest of it out. It is probably made of plastic so it should be easy to drill.[pre][/pre]
sensor removal youtube
Acetone should weaken and soften the rubber, but it would also make it swell in the process. So if it is too swollen already I don't know if that won't do more harm than good.
Andrew H.
