oblong box
dj4244
48
Hey guys
How do you put an obling box aroung the text of a dimemsion? I looked in help but no help.
David A. Johnson
Thunder Systems Inc.
Corona, CA
We call it a "Critical Dimemsion"
David A. Johnson
Corona, CA
Dim teh Feature, in the Dimension dialog box, set your Tolerance/Precision drop-down menu to Basic. That should give yo uwhat you are looking for.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Doh! Oblong... meaning rounded corners.
Dimension dialog box, click on More Properties at the bottom, then check Display as Inspection Dimension.
Ray Reynolds
