Obtaining mass and stiffness matrices in cylindrical coordinates 1
alain10025
New member
CA
I am using Ansys to study a cyclic symmetric structure. But I just use it to obtain the mass and stiffness matrices of an elementary sector.
In order to make the analyze of the matrices easier, I need to obtain them in global cylindrical coordinates. It is why I have a problem.
After importing my FE model in Ansys (the elementary sector), I use the commands :
- CSYS,1 to work in cylindrical coordinates
- EMATWRITE, YES
- WRFULL to get the files containing the mass and stiffness matrices.
However, this seems unefficient because I get the matrices in global cartesian coordinates.
Would anyone know which command is required beside of "CSYS,1" to be sure to obtain the matrices in global cylindrical coordinates ?
Thank you.
Alain
I don't know if what you want is even possible in Ansys. It it is possible, then csys,1 would not have any effect anyway.
RSYS,1 on the other hand could have a chance to do, what you would like to do.
Alex
sometimes it's the "DSYS" command which governs the listings of coordinates. If the suggestion of the "RSYS" doesn't work, I'd have a try with DSYS.
I tried RSYS,1 and DSYS,1 none of them seems to give waht I am looking for ... I know this is possible to do with Ansys because I did it already with another structure that was imported from Nastran.
In order to knoe where could the problem be from I edited the .db files of the previous structure and the one i am studying now, the only differences (beside of the structures data) are in :
Record 2 -> 5th position ("1" instead of "0")
Record 7 -> 61st position ("6" instead of "-1")
I tried to look in the Ansys Interface Guide but I couldn't find the meaning of these records in an input "db" file ...
Thank you for your help.
Alain
Ah, perhaps I've got an idea: rotate the nodal and element coordinate systems to a cylindrical one. Note that this may not be done with the default CSYS,1 so you have to replicate to a local user-defined one for example CSYS,11.
To rotate the nodes:
CSYS,11
NROTAT,all
To change element's coordinate system:
EMODIF,...
Thanks a lot cbrn, it seems that
CSYS, 1
and then
NROTAT, ALL
can make what I was looking for !
Alain
glad it works!...
