thanhtang
- Jul 5, 2006
- 8
I have an 1' thick existing OCTAGON FOOTING down below the grade. On top of the octagon footing is an smaller existing octagon pedestal. The pedestal is 6' thick and 1' above the grade.
The existing foundation is currently supporting an old vessel. The old vessel will be replaced with a new vessel of the same kind. The existing foundation will be reused if possible. My task is to check if the EXISTING FOUNDATION is adequate to support the new vessel under new Codes.
There are vertical load, moment, and shear on top of the pedestal. I can calculate the total moment M and vertical load P at the bottom of the footing.
I need to CALCULATE THE FOOTING BASE PRESSURE to compare against soil bearing capacity provided from Geotechnical Report. I also need to CALCULATE STABILITY RATIO.
I know how to get it if the footing is rectangle, square, or round, but not octagon. My text books did not help.
Please advise me with approach, formulas, etc. for an OCTAGON FOOTING, not round footing.
Footing and pedestal size or details and applied load orientations are not necessary to be posted though.
PS: I have posted this in Soil Mechanic Forum, but I think here is more appropriate.
