MechEngMSU
I am designing a short 24" class 150 piping section to ASME B31.4 with blind flanged ends that will be used for liquid hold-up of NGL test samples to be intermittently pumped backed into the process stream. (The client doesn't want an ASME vessel and this is open to the flare with CSO valves).
Am i justified in tapping the blind flange off center with a 2" NPT tap or welding a flat weldolet to the blind flange? I read the code and believe I am required to design the closure to ASME Section VIII appendix II per B31.4 408.1.(d) but this requires a thicker than standard blind flange.
I have considered putting ASME section VIII heads with a nozzle. Is adding the nozzle designed to ASME Section VIII allowed per b31.4 406.6.3?
