borsht
- Oct 9, 2002
- 268
I've been trying to offset a group of edges to a sketch, and noticed that it's not showing the offset geometry until I finish the command. And then if it's the wrong direction I have to undo and redo with the directional check box oppositized to what it was. I have a memory that it used to shadow the new geometry before completing the feature, where I would fill or clear the checkbox as needed. So #1 is my memory failing me on this and that I am confusing solidworks with an inferior software? Or #2, Is there a switch in the options that I haven't been able to locate that would turn on that ability?
And yes, I have updated my Graphics Card driver to one that the SW Gods passed with flying colors.
SolidWorks Newbie since 2001
-Currently using SW2017
Inventor Newbie since 2019
-Currently using Inventor19
