Offshore Crane Curve (DAF applied)
Cengsubsea
Marine/Ocean
May 2, 2022
1
Hi there,
I am wondering if someone may clarify a query relating to offshore/subsea crane charts.
I have a requirement to lift a static load from a vessel and place it subsea. The crane curves I have available have a DAF applied of 1.3 (subsea DAF as per DNV) but I have an analysis DAF of 1.4 which needs applied. How do I approach this? Can I multiply my static load by 1.1 to make up for the crane curve only having a DAF included of 1.3?
Further, what would I do in the case of only having a calculated DAF of 1.2 but a crane curve chart DAF of 1.3? My available radius for lifting will be unknown.
Your best resource by far is going to be to call the crane manufacturer and tell them you need assistance engineering a critical lift. I doubt anyone here (certainly not me) is going to give you direct advice which might cause a subsea lift to fail... You're on dangerous ground.
Dynamic Amplification Factor.
The short explanation is that this is a crane derating multiplier which accounts for the fact that if you're lifting a load in the ocean, that load is experiencing sinusoidal movement, which increases the actual load applied to the crane by a load of a given mass.
It's not something to be messed with arbitrarily for a crane pick anywhere near load or radius limits.. which is why OP needs to call the manufacture of their crane, or whomever they are leasing the crane from.
