Old Deck Inspection Issues 7
fabbdc
8
I am perplexed. I’m Inspecting a deck that a home inspector requested a structural evaluation be done by an engineer. The deck is 27 years old (two stories with 4x6 post), but has been well kept (very well kept). I see all sorts of problems related to current codes: 2x8 @ 24-inch joist with an 11 foot span, 1/2-inch (assume through) bolts at 48-inches oc on the ledger, no knee bracing …. The problem is the deck is solid and has been working fine for 27 years. No signs of distress. I know that since it is existing, it needed to meet the code at the time that it was built (which I don’t have but I doubt would have been much different; I’m pretty current on the last 15 years).
The deck is solid, plumb and true (which I was surprised by). Jumping up and down, you really feel minimal movement. I have seen much worst.
The deck is solid, but how can I state that (seal it) when I know it is out of spec. I can’t believe it is as old as it is, the thing looks great. I have problem changing up things (and costing the owner big bucks ) that evidently have worked for the life of this deck. Based on the current up keep, I would not be surprised if they got another 20 years out of this deck. I am amassed at how solid it felt and looked.
How can I say its OK?
PEInc -
Done ALL the time - called "strong arming". I am not only a PE but I was in the real estate biz for about 10 years....
Sure - buyer wants a new deck!!!
I agree with PEinc. Only if the home inspector found the deck to have structural deficiencies should he recommend an engineer's analysis, that's his job.
From what I understand from Appendix J "Existing Buildings and Structures" of IRC, if existing conditions are proven "Dangerous", then those elements need to be brought up to current code. IRC AJ201 defines "Dangerous" as an 150% allowable.
