pssriram16
I am using Controllogix plc ,devicenet scanner card to read OMRON drt1-232c unit(devicenet to serial) which has a peripheral device connected to its serial end(in this case it is a weigh scale). i wuould like to know how the memory I/O is mapped on the devicenet memory. i setup using RSNetworx for devicenet. I am able to see the device using EDS provided by OMRON. But when i go to properties it does not give me the I/O address.
Also one more problem is that on the RSLogix tree IO Configuraion, for example if using a device for controlnet one can add a module (Generic controlnet device), but one cannot add a devicenet device from the io configuration.
Can anybody tell me how to send commands and receive responses through the DRT1-232C unit on a devicenet network? I have send commands using RSLogix.Thanks.
