88SST56
Marine/Ocean
- Sep 16, 2003
- 3
What are the determining factor that a designer uses to determine which tail configuration they use. I understand the reasons for the "T-tail configuration" when used with rear engined aircraft. Some examples of the different configurations in use are:
The Dassault FALCON 50, 90, 900, 2000 and FX all utilize the middle span ANHEDRAL style stabilizer, the FALCON 20, however, uses the slightly DIHEDRAL mid-span stabilizer. CITATION II, V, 500, and 550's all use a DIHEDRAL configuration. LEARJETS use the T-tail configuration exclusively, the HAWKER-SIDDELY 125 use a T-tail configurtion, and the anachronistic WESTWIND uses what looks like, a low conventional stabilizer. Any explaination on the positive and negatives of each configurations would be great. Thanks everyone.
