gelsi
Chemical
- Oct 18, 2010
- 81
an other question.
Normally, several plants have one relief valve that protects more than one equipment.
I think it's a good design criteria to minimize the number of valves but if there is the fire contingency, maybe it's better to install more valves:
[ul]when the equipment group is located in more than one fire area, a valve each fire area sub-group of equipment seems a better solution[/ul]
[ul]when there is a two-phase line, for example an overhead line from column, through a cooling water condenser to separator, it is possible a dangerous surge during the relief[/ul]
[ul]when there are many meters of line between the equipments, because of pressure drops, the overpressure can become too high (more than 121% of design pressure) [/ul]
what do you think about?
when is this practice not recommended?
an other question.
