insajn
- Apr 2, 2017
- 26
If I have a parking lot to design with hollow core slabs I have the dimensions in the attached file.
If the panel is 12 X 12.6 m and I placed the direction of the hollow slab parallel to the 12 m span and supported at the 12.6 m span beam. should I design it as a one way or a two way ?
I know it's supported on two parallel beams only but after putting the screed over the slab and beams wouldn't it behave as a two way ?
So I believe I should design it twice, considering first one way only to design the 12.6 m beams and then use the two way load distribution to design the 12 m beam ?
Am I right ?
Am I right ?
