planc
- Mar 3, 2022
- 64
For slabs with ratio greater than 2. It is considered one way slab with the reinforcements in the short directions.
But for sake of illustration. Supposed you put reinforcements in the long directions only, and no reinforcement in the short directions. Will it work if the reinforcements are four times greater?
This analogy is to analyze a concrete wall that is supported by the columns only without any top beams. If you put very big rebars or even angle bars between the columns every 39.37 inches (one meter) height of the concrete wall. How would it behave (analogy is just like slabs with ratio greater than 2 where you put reinforcements in the long directions only).
