Open a draft from an assembly
Fonzee78
35
0
0
Is there a way to open a draft of an assembly by right-clicking or some other way instead of just going to open and finding the draft. For instance in SolidWorks if you right-click on a part or assembly it gives you the option to open the drawing from th menu.
thanks!
Kenat is correct, Solid Edge works differently in this regard. We use “where-used” to find drafts. Fortunately with Insight Server the search process is relatively fast.
Solid Edge ST3 MP5 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
