When using a closed center valve what is the normal practice used to keep pressure off pump when valves are in center posistion? Doing no work.
I used air to check if fluid would circulate through the valve when spools are in center posistion. No circulation which leads me to beleive the pump would be under a High load when doing no work.
Using a Husco 5000 series double action motor valve in tandem and wish to controll 2 motors in forward, reverse and one forward while the other in reverse. Like in a zero turn mower. Built this thing from scratch. Only a fool like me would do this. I have a million hours in it and enough $ to buy a cheap one. Don't recomend anyone to build your owne. I understand fluid circuts untill I get to the question above. Thanks.
