milwaukeebob
- Jun 21, 2004
- 42
Hello forum members,
It's been a long time since I posted. Took some time away from the industry but I'm back and looking for some guidance. I just ran into something I've never seen before. Project I'm on has a small 3kVA xfmr 3-phase, open-delta, open-delta winding configuration, 240V primary/120V secondary (see attached pic of nameplate). This xfmr feeds only a single load - an outdoor 120Vac GFCI receptacle. The xfmr is fed from a 3phase, 4wire panel (400V L-L/230V L-N) but with a single-phase molded case circuit breaker...so 230V L-N.
The engineer of record on the job has informed us to connect the primary side 230V single-phase L-N to H1-H2 respectfully with the ground conductor connected to xfmr chassis ground. The other primary taps and winding (H3/H4/H5/H6/H7) are all to be isolated/insulated. On the secondary side the 120Vac L-N to the GFCI is to be connected to X1-X2 respectively (with winding X3 isolated/insulated) and X2 terminated to xfmr chassis ground.
I have only seen open-delta, open-delta once in my career but only on a 3 phase circuit. I've argued this xfmr is not right for the application and violates the Code. Any help is appreciated.
MB
MB
