doublee
- Oct 31, 2000
- 1
At a remote site the utility company only has two primary phases available and has provided an open-delta 120/240v service to a pumping station containing a 15hp pump and misc. lighting and controls. Any help on the following questions would be great.
1- The % voltage imbalance is +4% leading to high currents.
Is a buck-boost transformer the best solution? How do I size and connect it for the best results.
2- Running under the above condition of voltage imbalance the motor is very, very noisy. Is this the result of the voltage imbalance?
