Open Igs assembly files into CATIA V5
karthik1413
Automotive
SE
Hello ,I have a problem importing igs files as a whole assembly in CATIA.When i am trying to import them ,they are opening up in several windows.I want to open them in an assembly.Is it possible or do i have to save all those igs files into CATpart format and then open them in the assembly??
Please Help .Thank you !!
How are you importing them?
File>Open?
Use Insert/Existing Component. You can multi-select all the iges files to import into 1 assembly file.
Thank you Very much!! I was trying File open and then i tried insert new component/part instead of existing component.Thank you once again!!
