open .pps from another .pps 1
meh485
Computer
Jul 27, 2006
hi everybody
im trying to write a macro for the user to open pps file and them click a button and by clicking that button it will run a macro to open another .pps file.
can anybody help me with this.
thank you all
I use a standard function which will open ANY document that has a default app registered.
Code:
Public Function OpenDocument(DocumentWithPath As String) As Long
    OpenDocument = Shell("RUNDLL32.EXE URL.DLL,FileProtocolHandler " & DocumentWithPath, vbNormalFocus)
End Function
In your macro you can then use
Code:
x = OpenDocument("c:\mydoc.ppt")
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts:
thanks this does work but it displays an alert
i tried to do application.displayalerts = false
but the message still comes up
the message says:
"The command cant be performed because a dialog box is open. please close open dialog boxes to continue."
the message only lets me click ok, when i click ok and exit the slideshow, it than opens the slideshows i want.
i need for when the macro runs, the spreadsheet opens simultaneously.
thanks
