Open TeamCenter Item from NX Navigator
Barnon
Seems like you should be able to click on a component in the NX navigator and open that Item in TC. Only way I've found is to right click the component copy the name from properties and paste it in TC item search.
Years back when I worked for this company I wrote a grip that would suck out the part name by selecting a component from the Navigator, file to a text file and startup a AutoHotkey script that would take that Item name and past to the TC search window. Now they have the Blade Server permissions so I can't even run a AHK script.
We're running NX 12 BTW
If you right-click on your component, you have the option "Teamcenter Information".
This should bring you to Teamcenter and show the part you had selected.
But...most probably it will bring you to the Teamcenter Navigator in NX, not to the rich client.
Can't test this because we have Active Workspace as Navigator in NX
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Hi Didier.
I don't seem to get any option to open TC from the NX Navigator.
Thx NutAce.
You're correct it does open select component in an NC Active Workspace. I'm not used to working in that space (maybe I should be). Doesn't seem like I have all the options as in the real TC client.
Hi Barnon,
Sorry for the mistake. I was talking about the TC Navigator and not the Assy Navigator
Didier Psaltopoulos
To my knowledge this action does not exist.
If you run the "Active Workspace", a dedicated Teamcenter tab will exist in NX , with some of Teamcenters capabilities enabled.
I think for example that you can release an item from the Active workspace in NX.
I do know that the option to, easily, open a related drawing from NX when you have the model loaded will be implemented "soon". ( i have no date nor NX version)
Tomas
This is the Journal I use to pull up drawings from the Models in the Navigator. I think I got it from this site. I had to add buttload of extra extensions since we don't seem to follow any specific naming convention for our drawings.
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpen.UF
Imports NXOpen.UI
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim workPart = theSession.Parts.Work
Dim theUFS As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
Dim theUI As UI = ui.GetUI
Dim curSession As NXOpen.Session = NXOpen.Session.GetSession()
'Dim lw As ListingWindow = theSession.ListingWindow
Dim lg As LogFile = theSession.LogFile
Dim SelectedList As New List(Of String)
Dim bolSelected As Boolean = False
Dim objSelected As NXObject
Dim intType As Integer
Dim intSubType As Integer
Dim ExtensionList As New List(Of String)
Dim blnFoundSpec As Boolean = False
Sub Main()
'lw.Open()
lg.WriteLine("~~ Journal: Open_Specification.vb ~~")
lg.WriteLine(" timestamp: " & Now)
BuildExtensionList()
Try
lg.WriteLine(" Find out if components are selected.")
AreComponentsSelected()
If bolSelected = False Then
lg.WriteLine(" No components are selected.")
lg.WriteLine(" Open drawing for current work part.")
OpenDrawings(workPart.GetStringAttribute("DB_PART_NO") & "/" & workPart.GetStringAttribute("DB_PART_REV"))
OpenDrawings2(workPart.GetStringAttribute("DB_PART_NO") & "/" & workPart.GetStringAttribute("DB_PART_REV"))
Else
For Each selectedcomponent As String in SelectedList
lg.WriteLine(" Components are selected.")
lg.WriteLine(" Open drawing for selected parts.")
OpenDrawings(selectedcomponent)
OpenDrawings2(selectedcomponent)
Next
End If
If blnFoundSpec Then
curSession.ApplicationSwitchImmediate("UG_APP_DRAFTING")
Else
MessageBox.Show("(NO DWG found)", "", MessageBoxButtons.OK, MessageBoxIcon.Stop)
End If
Catch ex As Exception
lg.WriteLine(" Error in Sub Main: " & ex.Message)
End Try
'lw.Close()
lg.WriteLine("~~ Journal: Open_Specification.vb completed ~~")
End Sub
Sub AreComponentsSelected()
Try
Dim intNumSelected As Integer = theUI.SelectionManager.GetNumSelectedObjects()
If intNumSelected = 0 Then
bolSelected = False
Exit Sub
End If
For i As Integer = 0 To intNumSelected-1
objSelected = theUI.SelectionManager.GetSelectedObject(i)
theUFS.Obj.AskTypeAndSubtype(objSelected.Tag, intType, intSubType)
If intType = UFConstants.UF_component_type Then
Dim theComp As Component = DirectCast(objSelected, Component)
SelectedList.Add(theComp.DisplayName)
bolSelected = True
End If
Next
lg.WriteLine(" Error in Sub AreComponentsSelected: " & ex.Message)
End Try
End Sub
Sub BuildExtensionList()
'Add new extensions to this list.
'This list should be sorted by most commonly used extension as opening will be attempted in this order.
ExtensionList.Add("-1")
ExtensionList.Add("-Dwg")
ExtensionList.Add("-dwg")
ExtensionList.Add("-DWG")
ExtensionList.Add("_Dwg")
ExtensionList.Add("_dwg")
ExtensionList.Add("_DWG")
End Sub
Sub OpenDrawings(ByVal OpenMe As String)
Dim strExtension As String
Dim strSplitString() As String = Split(OpenMe, "/")
Dim strPartNo As String = strSplitString(0)
Dim strRevNum As String = strSplitString(1)
Dim strOpenString As String = ""
For Each strExtension In ExtensionList
Try
'MessageBox.Show("@DB/" & strPartNo & "/" & strRevNum & "/specification/" & strPartNo & "-" & strRevNum & strExtension)
strOpenString = "@DB/" & strPartNo & "/" & strRevNum & "/specification/" & strPartNo & "-" & strRevNum & strExtension
Try
theSession.Parts.SetNonmasterSeedPartData(strOpenString)
Dim prtBasePart As BasePart
Dim lsBasePart As PartLoadStatus
prtBasePart = theSession.Parts.OpenBaseDisplay(strOpenString, lsBasePart)
lsBasePart.Dispose()
blnFoundSpec = True
Exit For
Catch exc As Exception
Dim prtPart As Part = CType(theSession.Parts.FindObject(strOpenString), Part)
Dim lsPart As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSession.Parts.SetDisplay(prtPart, False, True, lsPart)
lsPart.Dispose()
blnFoundSpec = True
Exit For
End Try
lg.WriteLine(" Error in Sub OpenDrawings:")
lg.WriteLine(" " & ex.Message & ": " & strOpenString)
End Try
Next
End Sub
Sub OpenDrawings2(ByVal OpenMe As String)
Try
'MessageBox.Show("@DB/" & strPartNo & "/" & strRevNum & "/specification/" & strPartNo & strExtension)
strOpenString = "@DB/" & strPartNo & "/" & strRevNum & "/specification/" & strPartNo & strExtension
Try
blnFoundSpec = True
Exit For
lsPart.Dispose()
blnFoundSpec = True
Exit For
End Try
End Try
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
Why don't you use the Reference in Teamcenter to find it? for the selected 3D just find the Manifestation or Specification (don't know which relation is used in your Teamcenter) which is referenced by it.
Then you don't need to know the name.
NX9 / TC10.1.2
NutAce.
I would like to learn about the method you speak of. The above program has worked flawlessly except for one part that I have changed the name many many times and it still will not work. The above program seems to be pulling them from the name shown in red below. How can I find out which relation is used?
You can find the relation using Impact analysis in Teamcenter.
Check if you have the Were referenced Pom option. If not, then you have to create it in the Teamcenter options as below.
Be careful, you have to use the exact upper and lower case in the preference naming, otherwise it will not work.
Once created, select the UGPart. it will show the relations in the Impact analysis.
Right-clik on the "clips" and select view properties.
Do this for each clip until you find the one showing the UGPart as Primary reference and the UGMaster as Secondary.
It should show you the relations as shown below.
I actually learned at PLM Europe last week, that the "Open Drawing" functionality will come in one of the next releases of NX. I believe it will be in NX1899
NX9 / TC10.1.2
Thanks NutAce. Is there another way in the Journal to access that directly?
I would say this is the easiest. The only other one I would say is looking for it by name, but then you have to have strict naming rules.
NX9 / TC10.1.2
