Open Ug
bsvk
10
Hello all,
I have some problem with User Functions on "flat pattern". Any Open Ug Expert is here?
My problem:
I'm using the "uf_smd_create_flat_pattern" in my program. While executing the function in Ug it is almost generating the flat patter(99%) then it gives me"Internal error: Memory acces violation". I'm sure I have allocated enouch memory for required variables. I believe it may be a bug. Also I have reported this as an issue with UG and they replied the function is working well.
No I need some help to resolve this. Anybody could help me on this. If necessary I'll give the codes(or it can be taken from uganswer also).
bsvk
