Serhiy2
- Nov 10, 2018
- 44
Good day. I'm analyzing the existing Open Web Steel Joist for new load. The existing joists are made by Omega Joists, Canada and are dated 1999. I'm trying to determine top chord capacity which is in the shape of hat channel and is 2.36mm thick. Using the approach given in steel and cold-formed design codes, flexural-torsional buckling is the governing mode of failure in compression. I'm assuming that top chord is laterally and torsionally restrained at panel points. Given that my webs are flattened at ends, the assumption about torsion-restrained top chord at panel points feels to be a bit stretched. Wondering, how do you guys normally deal with something like this?
Also, given that corrugated roof deck is welded to top flanges of the top chord hat channel, would it be reasonable to assume that roof deck provides continuous torsional restraint to my top chord member?
