I am designing a pressure vessel using compress software .the PV is 24" OD and has a bolted cover.
we want to use standard slip on flange & blind flange but we need to make an opening in the blind and we can't do it in compress.
1) can we use a UG-34 cover with the same dimensions of standard blind flange to easily make an opening and in fabrication process use standard blind flange and make the opening for nozzles.
2) Why did compress prevent to make opening for nozzles in standard blind flanges? Is it forbidden by code ?
