Csaba Solyom
I have an issue with opening STEP files, with different settings based on how a STEP file is opened.
NX version: 1919 (Build 3400).
STEP type: AP214
Issue:
[ul]
[li]Opening the STEP-file using drag-and-drop from Windows Explorer into NX, it imports only the solid and surface-model (geometric) elements, without CSys or Datum Planes.[/li]
[li]Opening the same STEP-file using the File->Import->STEP214 menu will offer the option to import CSys and Datum Planes, and imports all features as expected.[/li]
[/ul]
We'd like to change the drag-and-drop settings to use the same as the Import-STEP214 uses (that menu retains the last used settings), so opening STEP files is consistent for everyone, regardless of method. Right now this difference creates constant issues when passing files around between departments or different physical locations.
Any ideas how to change the settings for drag-and-drop?
Thanks!
STEP type: AP214
Issue:
[ul]
[/ul]
Thanks!
