I will be implementing a pneumatic 5/3 valve to control a double-acting cylinder. The valve has two solenoids(for this post I will designate them as S1&S2). I assume that when..
S1=ON & S2=OFF, this will be Position1
S1=OFF & S2=OFF, this will be Position2 (center)
S1=OFF & S2=ON, this will be Position3
however, what will result if...
S1=ON & S2=ON, Is the result unexpected (or unstable)?
Should the solenoids be electrically-interlocked so that only one solenoid may be energized at a time?
