I searched around and couldn’t find anything, my apologies if this has already been posted.
Does anyone know any good resources that cover optimal sheet metal geometry?
My application involves something similar to the bottom of a soda can. It is about the same size as the soda can, only differences are that its made out of soft stainless, the bottom is convex instead of concave, and the bottom "convex piece" is welded to the cylinder, not extruded from one piece like a pop can. My lid looks likes if you took the lid of a can of paint and instead of having it flat, made it into a subtlety domed shaped lid. Note the lid of the can of paint has a “U” shaped bend geometry around the edge (the lip). I am trying to figure out what type of geometry would result in the high moment of inertia aka resistance to bending. The radius of my “U” bend around the edge (aka the lip) is currently 2.5 times larger than the minimal bend radius (assuming for my material the min band radius is .5 x thickness).
A secondary issue is that despite being 2.5 times larger than needed, the vendor sometimes delivers the product with cracks around the bend radius. I am thinking it is a tooling issue on his end; the dies are wearing out or something. It doesn’t occur often, but I see runs where it does occur sometimes. Any other ideas on what would cause that?
