Redacted
- Mar 12, 2016
- 160
Hi there,
I'm working on a project where a wall will be coming out and a new 6' doorway will be put in. The architect will be bringing up the floor level, which reduces the space to add a beam to 1.5". The beam is lightly loaded and is just holding up the roof. However it also needs to hold down the roof in heavy winds. I've never had to design a beam this shallow before so I would appreciate any advice on how to go about doing this correctly.
As there is only 1.5" of depth allowance for the beam, I'm thinking that the only main elements that I can consider are :
1. Flat plate
2. Steel angle (although would I have issues with torsion with this element).
I tried to sketch my thoughts below.
The timber wall plate is only 4", so I'm thinking that the width of the flat plate would only need to be 4" as well. However, my concern is that this would also need to hold down the roof in high winds and I'm wondering if this element would cause the roof to be bouncy, as it doesn't have much rigidity? The wall that the steel beam would be bearing on would be made of filled CMU block.
Note that the opening is only ~6'.
Is there a better approach that I can and should take for this?
Any help would be greatly appreciated.
1. Flat plate
