Opto-Electrical Ciruit Problem 1
araz
3
I have an opto-electrical circuit design using an optical transistor OP506A, and an Operational Amplifier TL072. When the Optical-eye is covered (no light goes to the optical eye), positive input (Pin 3) of the TL072 goes to +5V, then the output of the TL072 is triggered.
The Problem:
when the Optical eye is covered or darkened continuously (For Example: the device left "ON" in a dark room at night), the output trigger is repeated continuously. How could I prevent the continuous trigger of the out put? Could I change my Optical device to a one that trigger once? Any body has any idea?
I thank you all people in advance.
ARAZ
Suggestion: Visit
for more info. Why is TL072, Dual Low-Noise JFET-Input General-Purpose Operational Amplifier applied? It has more complex internal circuitry. Would not a Single Low-Noise JFET do? Also, it may need a new optical transistor and to verify its characteristics in the design circuit.
