Can anyone advise how to determine the Critical Pressure Ratio at which a Square Edge Orifice Plate with compressible fliud reaches critical (sonic) flow and the flows at pressure ratios beyond the critical ratio.
I need to correctly predict flowrates through pressurising and blowdown restriction orifices from high pressures where dP/P1 ratios are as high as 0.98 and the readily available texts do not provide the solution.
Almost all of the orifice plate calculations identified are for accurate measurement flows below the critical range and limit dP/P1 to say 0.35 or 0.6 to ensure the flow is subsonic.
Crane TP410 provides the formula for critical flow but first the Net Expansion Factor Y chart on A-21 is only provided up to dP/P1 = 0.6 and second the Critical Pressure Ratio chart on the same page is only provided for Nozzles and Venturi Meters and not for Square Edge Orifices.
I understand that the flow will continue to rise as the downstream pressure falls further because the vena contracta grows in diamter.
Dennis Kirk Engineering
