I'm designing an outlet structure for an underground infiltration bed. The bed consists of perforated HDPE pipes in gravel. The pipes will tie into a precast manhole that will outlet larger storm events.
The outlet pipe will be a 15" diameter RCP that connects to the city sewer.
I calculated that I need a 3" orifice for a 100YR event, and that water will only rise to about 5" above the center of the orifice during this time. I therefore plan to cover the opening to the 15" RCP at the manhole, using an orifice plate that covers it's lower half (leaving the top half open for emergency overflow). However, being very green at this, I'm having trouble trying to figure out the most efficient way to do this.
I found a detail on the internet, at the city of columbus's website. they use a .25" diameter aluminum plate, rolled to match the curvature of the manhole. the plate is anchored to the manhole wall with stainless steel, epoxy anchors.
Has anyone used a detail like this? If so, does it work well? If not, would you have any other suggestions?
Thanks.
Thanks.
