hosec
- Jan 30, 2001
- 6
Are you able to advise the size of an orifice plate that will be fitted into a fire hydrant main to give a pressure drop, (when 1 hydrant is running at full bore) from 180 psi to 55psi.
The main is Thin Wall Stainless Steel line with an internal diameter of 150mm, and a fire hydrant connection is nominally 50mm dia.
