origin
mayrou
55
hello everybody!
I tried to create a macro that give me the origin of a selected cercle!
Code:
MsgBox "selectionnez un trou"
Dim InputObjectType(0), Status1
InputObjectType(0)="Hole"
Status1=selection1.SelectElement2(InputObjectType,"Select un trou",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Dim reference1 As Reference
Set oHole = selection1.Item(1).value
'************************Origine du trou********************************
'get the origin of the hole using the variant object
Dim origin(2)
oHole.GetOrigin (origin)
Msgbox "Origin = " & origin(0) & ", " & origin(1) & ", " & origin(2)
i tried this one but it gives wrong values!
The Hole must be selected..
Code:
Sub origin()
Set oDocument = CATIA.ActiveDocument
Set oHole = oDocument.Selection.FindObject("CATIAHole")
Dim origin(2)
oHole.GetOrigin origin
MsgBox "Origin = " & origin(0) / 25.4 & ", " & origin(1) / 25.4 & ", " & origin(2) / 25.4
End Sub
thank you AlexLozoya for you help! :)
the hole is already selected! but what "25.4" refers to?
after all, the values still wrong :(
Alex assumed you are using inches while CATIa script only use mm, so 25.4 will convert mm to inches.
Eric N.
