Laboratorio TRF
Materials
Hello everybody,
I work in a company that produces seamless tubes through cold-drawing method. Sometimes for stainless steel tubes (TP304 and 316) of low wall thickness (1.75mm and below) after solution heat treatment at 1050°C in a continuous furnace, the ultimate tensile strength of tensile test is higher than maximum allowable in EN 10216-5. This does not happen for "heavier" tubes. I have tried heat-treatment with lower passing speed through the furnace, but could not resolve the problem.
can someone give me an explanation for this?
