Output question
ssn3
20
I have a small question on outputs such as E11,E22,E33,S11,S22,S33,U1,U2,U3 etc. Lets say I have use an orthotropic material and have defined the different material orientations. The outputs I mentioned earlier, are they based on the global coordinate system or the local coordinate system that I used to define the material orientation? Is there a way to get the outputs based on global and local at the same time? These are the questions that I would really need an answer too. Hope someone could help me with this. Thanks in advance.
Yes.
Search "local coordinate system" in the CAE User's Manual. CAE lets you carry out the transformation.
Are you new to this forum? If so, please read these FAQ:
I created a simple model to test this out. Using a orthotropic material I kept changing the orientation of the material. Based on this simple test I am pretty sure it gave results for E11,E22 and E33 based on the local material orientation. I used unique nodal position to get the output values. Not sure if I am doing it right.
