gcpdesign
Automotive
- Feb 2, 2005
- 64
Hello All,
Problem:
I have a product with many supplier items. most of these items are just dumb block solids which does not reflect the true volume of the item. eg. a pneumatic cylinder is hollow with a piston & rod. it also has mildsteel & aluminum parts. the supplier models most times dont come with the "guts". So, when we check the properties of these items they weight eiter much more or less. As i'm sure you'll understand that we don't have the time to go and re-model these items so it is correct.
Question:
Can one somehow over-ride the weight of these items, eg. in properties or even a parameter which would assist in weighing these item used in an assembly so one can get the proper COG, weight, etc?
Thank you in advance!!!!
Problem:
Question:
