saranac
Automotive
- May 18, 2005
- 13
I have a Question on Overcrowning. I am starting with a simple set of joined surfaces. If I apply dress-up I see a very low amount of control points and segments. The I ones I do see are in the areas of fillets. But after using Shape Morphing or Wrap Curve these surface are highly segmented and load with control points. I knew that there would be some increase of the control points and segments. But is there a way I can limit their size ?. Thanks For your Help Saranac
