AJ817
- Nov 3, 2020
- 7
We are having a discussion in the the office and are looking for some clarification. We have a project with wood trusses spanning 30' between load bearing walls. The trusses then extend out 10' on each end and are supported by beams and posts at the ends. I believe we should be using overhang wind pressures where the trusses extend out past the load bearing wall. One engineer says you can look at it as being enclosed/partially open and not use overhang. What are your thoughts?
