Currently I am working on a mantenance program for an export oil pipeline.
In discussions with suppliers of valves (16" side monted on/of ball valve, type with trunnion mounted ball valve, direct action), there is no clear answer to if there should be a defined interval for overhaul of these valves.
There is only a description of periodical functional tests of the valves.
Does anyone know if there is a requirement in API or equial for such overhaul/classing interval for such valve?
Regards KjetilK
Regards KjetilK
