123MB
- Apr 25, 2008
- 265
Hi All
Was sure I would find this in the search, but no luck.
Have an application where we have a 30kW motor with a 45kW vector drive. The motor is a fan which is controlling flow rate and requires good accuracy at very low shaft power (Its duty points are from 20kW to 3kW shaft power).
I'm almost embarrassed to ask this as it seems so simple but I can't work out how to determine the impact of the larger drive on the accuracy of the flow rate control.
I know that for vector drives, it is not good to oversize the drive too much since the accuracy of the current measurement is reduced, but it just doesn't make sense to me considering these drives should be able to operate in the full power range.
For example, to put it simply, if a 100A drive was used on a 100A motor, it would still be required to have sufficient accuracy and performance at power conditions resulting in 5A current. So why would there be any issues in connecting, say, a 50A motor to the 100A drive, the accuracy at 5A would still be the same.
Sorry if this is very simple I am just not getting it and I think I've had too many coffees.
Cheers
Cheers
