Dear group,
I need member's opininon regarding Ozone removal procedure in civil waterplant.
Namely, in the last stage of production process, H2O2 solution is injected in water stream in order to eliminate Ozone rez. and to lower it in accepteable level. The main question is how to inject or to apply relatively small quantity of H2O2 solution (about 0,1% of 500lit/h) in to 6 meters width water stream?
Is the H2O2 solution good choice for this particular application?
Sincerely,
Ivan Lazarevic.
Sincerely,
Ivan Lazarevic.
