JeremyBonelloB
- Apr 29, 2018
- 4
Good evening,
I am currently working on understanding the phases present in a quenched and tempered sample of P20S (1.2312) tool steel.
The quenching process was done from the austenitizing temperature and oil quenched for a number of seconds.
After quenching what I understand is that the present phases would be martensite and retained austenite. (55HRC)
After tempering which was done at 520oC for half an hour, from the information I gathered from different solid sources I managed to put together that the retained austenite transformed into martensite whilst the martensite transformed into tempered martensite. (42HRC)
What I am confused about is all the white inclusions present in the microstructure which is the microstructure after tempering.
Am I correct to say that there are only 2 phases present which are martensite and tempered martensite? Or does there still remain retained austenite?
