paddle blade design 2
disenador
Dear Friends:
I need a formula to find the force applied to a surface knowing the speed of the flow of water and the area of the blade.
Best Regards
Have a look at recent posts in the piping and fluid mechanics forum - there is some stuff on rudder design which should be applicable to your question. (It was in the wrong forum in the first place !)
Hope this helps.
Pressure = Cd.1/2.r.V^2
Force = Pressure x Area
Where r is density of fluid, v is velocity of fluid...Area
Cd = shape coefficient
Very simplistic approach, as there are other things to consider also
ops, sorry
Pressure should not have Cd term P = 1/2.r.v^2
Force = Cd.pressure.area
