painfully loud motor 1
foretmark
Is there any electrical mechanism that I'm just not able to figure out that would cause a motor running under typical conditions to make an exceptionally loud noise under load? I'm fairly certain it's mechanical, but I'm being told it could be electrical and I just want to rule out anything wierd. It is a pump motor and the pump and motor have both been replaced seperately and together and the noise continues. I'm told it's coming from the motor/pump assy.
EM noise would have existed from the beginning. OP hasn't indicated if this is a new installation or old. If this setup ever worked correctly? When did the noise start?
At this moment I tend to agree with 1000V.
Has a stethoscope or similar device been used to check whether the noise is in fact from the motor and not from the pump?
Bill
"Why not the best?"
Jimmy Carter
Good point, waross! Eliminate which part the noise is coming from, as I understood it.
I have a hydraulic pump which gets noisy when loaded at the workshop before. We singled-out the noise coming from the pump, the motor seems to run well. Turned-out to be an overload on the system and pressure relief partially bypasses and chatters causing the noise.
well, I wasn't there to witness anything, but I'm told a new pump with a lower flow rate fixed the noise problem.
Thanks for all the input....
