yasernoman
- Dec 6, 2007
- 4
I know this topic has been address in several forums, but none of the answers helped me too much.
I have a vessel that requires internal painting/coating. The senior engineer on the project insists that flange faces must be painted as well. Spiral wound gaskets have been specified for this vessel, with an option to use Grafoil gaskets. Vessel operates at 1000 kPa(g) and 150C.
1) Is there any document, guideline, code, standard, or specification that will clearly state whether painting on flange faces is permitted, not permitted, or subject to agreement between manufacturer and client?
2) Has anyone here had experiences with painted flange faces that were successfully operated with no leakage issues in the oil field / refinery environment?
3) Has anyone had any other experiences with this issue.
Your response is very much appreciated. Thanks in advance.
