Palettes directory
rafl
41
How to change the palette files directory location "C:\Documents and Settings\...\Local Settings\Unigraphics Solutions\NX6" to new one? IS there an environment variable?
Can you please clarify what exactly you desire to do ?
When I add new palette to the resource bar, nxpalette.pax is created in this directory; "C:\Documents and Settings\...\Local Settings\Unigraphics Solutions\NX6". All I want is to change location where .pax files are created.
I believe that there is / or used to be a environment variable that one could set, UGII_PALETTE_DIR (- correct ?)
But it does not exist default in the ugii_env.dat or the newer ugii_env_ug.dat, - One had to add it manually.
