jaswild
- Aug 30, 2005
- 3
First, I've done EE design work before, but it's been awhile and it was all experience based, I don't have a degree. So there are a couple things I've forgotten about loading a panel which I was asked to do recently on a computer job.
I have a 150A, 120/208V., 3P, 4W panel, which I've made a load chart for to determine the load on the panel.
First question - there are breakers in the panel that both connect to a single pole, but have an A & B connection per the diagram in the panel board cover, and there are dual 20 pole breakers, do I treat this as a 40/1 pole load? Therefore putting a 3840VA 80% max load on the B leg of the Y?
Second, once I've determined the VA load on each phase, what is the finishing calculation? When I previously worked as a designer, there were existing numbers for this, but I don't remember the calculation for coming up with it from scratch. So if I add the 3 phases together and have 44860VA total load on the panel, how many amps is that in design being used?
I apologize if these are simple questions, but I'm at a loss and just need to finish this simple task.
Thank you.
Jason
Thank you.
Jason
